Migrate existing WordPress installation to Cloudron
Overview​
Migrate a WordPress installation from another server or service to Cloudron using one of two approaches. Choose the method based on the tools available in your existing hosting environment.
Migration without a plugin​
This approach requires access to a File Manager for downloading site content and PHPMyAdmin for creating a database dump.
Export WordPress​
Export the contents of your existing WordPress installation:
  1. Export the wp-content/ folder on the origin server to a wp-content.zip file.
  2. Export the database on the source server to a .sql file. In PHPMyAdmin, select all tables and export to wordpress.sql.
Install WordPress on Cloudron​
Install the WordPress Developer app on Cloudron.
Import WordPress content​
Go to the file manager of the WordPress installation and navigate to the public/ folder:
  1. Upload the wp-content.zip file.
  2. Delete the existing wp-content/ folder.
  3. Unzip wp-content.zip.
  4. Change ownership of the unzipped wp-content/ folder to www-data.
Import WordPress database​
Upload the wordpress.sql database dump to /app/data. Open the Web Terminal and run:
# cd /app/data
# WP db reset
# WP db import wordpress.sql
Verify​
The migration is complete. Restart the app to verify the site works across restarts.
Replacing urls​
Some WordPress core files, themes, and plugins store full URLs in the database instead of relative URLs. Replace strings in the database using the WP CLI search-replace subcommand.
Open a Web Terminal and run:
# sudo -E -u www-data /app/pkg/wp --path=/app/data/public/ search-replace 'https://old.cloudron.space' 'https://new.cloudron.space'
# sudo -E -u www-data /app/pkg/wp --path=/app/data/public/ cache flush
Migration with all-in-one WP migration plugin​
This approach requires installing the All-in-One WP Migration plugin on your existing site.
Export WordPress​
  1. Install and activate the All-in-One WP Migration plugin.
  2. Click All-in-One WP Migration in the side pane and select Export to file.
  3. Download the migration file (.press extension).
Wp Migration All In One Export
  1. Install and activate the All-in-One WP Migration plugin on the Cloudron installation.
  2. Click All-in-One WP Migration in the side pane and select Import.
Wp Migration All In One Import
Verify​
Migration with UpdraftPlus plugin​
This approach requires installing the UpdraftPlus plugin on your existing site.
Export WordPress​
  1. Install and activate the UpdraftPlus plugin.
  2. Create a backup.
Wp Updraftplus Backup
  1. Download all backup files after the backup completes. There are 5 types: Database, themes, plugins, uploads, and others. Download each individually.
  1. Install and activate the UpdraftPlus plugin on the Cloudron installation.
  2. Upload the backup files and click Restore.
Wp Updraftplus Restore
Ignore any migration warnings.
Verify​
